99 NBS drivers door problem
This has been happening for awhile and is now getting worse.
I have a 99 GMC Sierra NBS 3 door. When i go to open/close the drivers door, it drops a few inches, and there is a lot of play(when lifting up on the door). Do to this at times it will not completely latch/unlatch.
I looked through my service manual and didn't see anything about how to adjust this? I did a search on here last night and found nothing either....any ideas on this?
Thanks..
There are pins, bushings, and hinges that hold your door together. Chances are that your doors have been open and closed enough that they have worn through the bushings and possibly the hinge. Depending on how worn out they are, you may need to replace more than just the pin and bushing. It is a pretty fast and easy job but does require either an engine hoist, ceiling mounted lifting device or 2 more people. as well as an air impact gun to make it go fast.
To see what needs to be replaced open your door, have another person lift the door and you look at the upper and lower hinges. see wich one has more play. also observe if the bolts holding them to the truck are loose, judging by how much play you are describeing.
If the hinges are loose tighten them up to the tuck more. if the pins them selves are have worn though the bushings, go to your local auto parts store and get new ones, bribe two friends over with beer and then comence pin/bushing replacement. If the pin has worn into the hinge more than i would say 1/8 of an inch, you need to replace the whole hinge assy ***suck*** and you will probably need to go to a chevy dealership and it will cost you alot more $$$
Excuse my spelling.
If i have missed something or have said something wrong, please correct it in another post, but this is my interpretation of the situation.
The NBS truck doors don't have the same hinges that the OLD body style had. With the NBS, to remove the door from the truck all you have to do is (1) Unplug wiring harness (2) disengage door-stop (3) remove 2 silver screws attached to each hinge (4) pick up door and remove. DONE!
found this site 4 the pins...http://www.dormanproducts.com/cgi-bi... gory_list=:0
Do you have any detailed info on removing the door? I'm in the proces of moving and my service manual is boxed up somewhere. looked all last night for the book with no luck. still have garage and storage shed to look ....:banghead:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,259 Guests (See full list)
