Anyone have a BedRug?
As the topic says I am looking for Members who have a BedRug installed in the bed of their Silverado or Sierra.
I am looking/thinking of getting one and I was wondering what folks thought about them.
TIA :thumbs:
I love mine! Got it mainly for looks. I now have a tonneau cover over mine and it gives a great custom look! Since it is padded I plan on getting one of those truck bed tents and sleeping on it this hunting season.
I've got one of those (truck bed tent) that I don't have a truck for anymore.... ;)
Thanks for everyone's positive feedback :thumbs:
I've been searching for 'best" pricing and it looks like $284.00 + shipping is the best I could find on the internet.
  • 3 months later...
  • 3 weeks later...
What's the deal on moisture and cleaning? Are there any drawbacks when that happens? Looks perfect in the sunlight. Great pic.
Looks great. But along with cleaning, how hard is it to pop out when you need to use the bed for what it's made for? hauling stuff like fire wood, sod, top siol ...?
I've never tried to pop it out again. When I'm hauling some real nasty stuff, such as a Deer carcass, dirt or something else, I just throw in one of those plastic tarps first. Works for me. Then a quick water hose or vacuum if needed and it looks great again. KS
  • 1 month later...
I had one in my 03 2500 HD. It was under a cap, so it stayed clean & dry. I did take it out about every 3 months & cleaned uner it. Do yourself a favor & get a set of tailgate seals. You can't believe how much water can get in & hide under a bedrug. I drive a Tahoe now, but if I ever get another pickup, I would buy a bedrug for sure. Good investment.
They are a pain when it rains as it drips forever. You can haul firewood on it though. A vacuum will clean it right up.
actually..... you dont.. or at least i have never popped mine out. but i also have a tonneau cover over it too, so it stays dry. otherwise just vacuum it out and drive on.
but yeah I love it. would buy another one if I ever have another truck. works great for hauling my bike, too. no greasy or gas filled bed to clean up.
Now I want a bedrug :confused:
you wont regret it!
it also has about a 1/4 - 1/2" of padding under the main bed area so if your hauling something that is fragile, it wont get busted as easily. and you can't hardly tear it either. you have to cut it if you want a hole or slit in it to poke the bed hooks through.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
