Center Conolse with Bose Sounds System
dacapeman
i have a 2005 Silverado Crew cab, Buckets with ceter console. This has the Bose sound system so there is a whole bunch of wires that run into the console. These go to the Amp that is in the base of the console and also to the rear radio controls mounted in the console. I have removed the console and doing so found out that the radio does not work unless connected to the amp. So i removed the amp from the console and connected it and the radio and front speasers work. Then the rear speakers will not work unless the rear radio control from the console is conncted. So I removed that and connected it. Now I have the radio working. Im guessing that when I put in the center jump seat, I can probably put the amp under the seat as well as the rear radio control box. I was wondering if there was something I could do to replace the rear radio control box and still have teh rear speakers work. I want to sell the console, but now there is an opening where the rear radio control goes.
Next step is figuring out when I need to fill in the opening in the dash where the console was.
I'm looking to add the rear controls in my 03. I have the controls but have not been able to find the harness I need. Would you be able to take some pics of this setup while it's out of your console showing how all this is wired? And does the rear control harness have a part #?
You should be able to find the pocket filler to replace the controls when you sell your console.
  • 1 month later...
    liddlera
    liddlera
  • Who's Online   4 Members, 0 Anonymous, 607 Guests (See full list)
