A?C compressor done!!
Hi guys
I am new on the GM world.
I own an Tahoe 1996 and the A/C compressor die.
Repair in the shop cost me like $1000. and repair myself I calculated
$400. some questions:
How hard is?
do I need special tools?( except vacuum pump and manifold)
I must to change the expantion valve and drier?
thank for every input
Andre.
it depends, are you still running R 12 freon, or are you r134a ? it will say on the compressor somwhere.
If its R134a You can charge it up yourself with cans from any auto parts store> You dont really need to vacuum it down, Ive done without that before. It cooled down as good as normal.
If its R12 you can charge it up with a Freon called HOT SHOT. it is a drop in replacement for it.
Otherwise do you know what caused it to break down? Is the compressor clutch bad, or do you have a leak? A totally empty system would cause Your compressor not to turn on.
Hi
Thanks for the info
I use 134a freon on my system.
and the problem is the compressor, it started leaking everywhere.
So I need to change it.
thanks again
Andre.
    Aries68
    Aries68
  • Who's Online   0 Members, 0 Anonymous, 357 Guests (See full list)
