Front suspension story
OK, I have a story. About a month ago I noticed that my brakes were starting to pulsate. Only 3 months earlier I replaced all of the pads and had the rotors turned. Well, the two front rotors were warped. So, I replaced them with some CarQuest OE rotors $40.00 each. The brakes were awsome after that.
Well, yesterday I started to notice a thump/clunk/rattle whenever I went over a bump or used the brakes under 30 mph. I did the wheel shake thing and noticed that there was some play in the steering. So, I took the truck to Chevy this morning and used my extended warranty ($100.00 deductable) thinking it was the tie rods or wheel hub/bearing assy. They replaced the inner tie rod (I don't even know if a rack&pinion has one of those) and lubed the intermediate steering shaft. Still did it. I took it back and they said that the inner brake pad on the driver's side was rattling. I wasn't sure how this could be because I greased everything and torqued everything to spec. So, I took an hour and disassembled the whole left front brake and cleaned/lubed everything and the problem went away.
While I'm glad this fixed the problem, I'm wondering if an ungreased brake pad can really cause a very audible noise like that?
Well, just wanted to share that. If anyone has any thoughts or experiences like this I'm open.
How many miles do you have on your Chevy?
Here's an update. The rattle came back about two days after I cleaned/lubed the brakes. I checked and, sure enough, one of the brake pads sits loose in the bracket. My question now is, how do I tighten it up. I shifts back and forth a little. The clips aren't bent or anything so I'm wondering how it loosened up. I brakes just fine and everything but when I'm driving along that one pad rattles every time I hit a bump or some rough road.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 583 Guests (See full list)
