Throttle body cleaning
I'm getting ready to flush my coolant system and figured while I'm at it I'll remove my throttle body and clean it. I have an '03 4.8L with the drive-by-wire system and wondered if there are any surprises? I have a new gasket and I know the coolant needs to be drained. Is there anything to be aware of with the electronic module that operates the throttle? Thanks
You probably wont have any residue in the drive by wire since the PCV system is entirely different but you only need to push the blade open with your finger and spray away. No need to remove the throttle body to clean.
Sam, I agree, you should not need to remove the tb.
I would suggest that you add a bottle of 96001 Kool It from Lubegard to your cooling system once you have complete the flush. This is a wonderful product that will reduce all chemically caused Electrolysis and is recommended by Modine, the premier mfg of radiators. We sell a lot of this product for this reason. It is alos designed to reduce your coolant temps but there is a lof of debate over this. If it does reduce your cooling temps, this is just a bonus.
Thanks for the replies. I noticed last time I pushed the blade open that it is gear-driven through the servo. Will the gears in the actuator be hurt by opening it manually? Just wondering.
Thanks again for the advice.
No it wontas long as power is off. I check it yearly on my 01 Corvette and hasent hurt it and dont have any residue on it either.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
