PIAA vs. Silverstar bulbs
Do they really make a difference compaired to the stock bulbs and is there any other mods or parts I would need or do they just plug right in?
Also does anyone recommend the High-4 kit?
I have the high-4 kit on my truck (not sure the exact brand name).
There are various kits out there, and if you're inclined, you can do it yourself for much cheaper.
Anyways, I like the 4-high mod....really lights up the road at night. ;)
thanks
I replaced my high and low beams with Silverstars............and did the 4 high thing........plenty of light now :fume: .......... :)
i like my silverstars much better than stock bulbs. i just wish it would last little longer. waiting to see how the new silverstar ultra performs.
Recent tests (Consumer Reports comes to mind) showed that the SilverStars did not produce anymore light than the factory 9006 bulbs, had a shorter life cycle and cost 2 to 3 times more.
Save your money unless you want the cool factor look :)
Whatever they say, I put Silverstars in headligts and fog lights, and a hi-low kit. and
they seem a whole lot brighter to me. Also, have had Silverstars in my wifes car for probably 2+ years with no trouble. And PIAA? talk about expensive! saw them for $80.00 a set.
I had one of my lows go out after a year.... Junk, I put the stockers back in and left the highs in. We shall see how long they last. I don't think the cost vs life is worth it.
I like the 4 high. I made my own (kit) for 12 bucks. I also put a relay on the lows so they get full power.
I have been using the PIAA 9005 & 9006 Extreme White Plus Bulbs(4000K) now for 4 years and have had absolutely no problems with them. They produce a lot more light than stock and work just fine with the factory Hi/Low system. I would choose these over Silverstars any day of the week. The extra cost IMHO is worth it as I keep hearing about the short life of the Silverstars.
I'm using SilverStar's for the low beams of my 99 and they have been in there for going on 4 years now. They do have more light output in lumens that the stock halogen bulbs and the color temp is slightly higher.
I also have SilverStar 6054 lamps in my 87 Vette and they are hundreds times better than the old stock halogen lamps that were in there.
  • 5 months later...
I have Silverstars in my high beams but stock in my lows since there is no Silverstar (H11) available yet. I really can not see at night with the stock. I am wonderinf if I should try the PIAA H11 until the SilverStars have that model of bulb.
I have a question, what is the high 4 kit mod? does it enable the lows & high beams to be on at the same time? if so where could I get that kit and is it at all difficult to install?
I would also like to know what this kit is. I have a 2001 Suburban, can I use this kit?
thanks
PIAA / SilerStar is the topic. I still want an answer which is better side by side. My truck has all 4 bulbs lit stock. Maybe this topic exists somewhere else.
THis is is for the bulbs! Come on!
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
