K&N FIPK/Aircharger for the Big Block 496
Anybody have experience with the new K&N airbox kit for the 8.1L (496)? I'm curious about:
Ease of installation - instructions, notes on tricky stuff
Performance observations - first observations, current
MPG - gains/losses (versus any new driving habits)
Sound - loud? annoying/ good?
Maintenance - filter cleaning...
Thanks - Dave
What you need is 57-3030 - check K&N site
http://www.knfilters.com/FIPKChev.htm
Replacement filter RF-1041 - you may want to order the foam cover at the same time RF-1041DK - check site for color options.
When you install watch the fan shroud. May want to take a Dremel and notch it. Instructions clear - 20 miutes max - remove battery negative while installing - then reconnect - this will reset the ECM - your truck will re-learn faster.
Sound, excellent - like an old fashion 4 barrel - if you want quieter check out Volant
http://www.volantperformance.com/
Performance: seat of pants [sOP] gain - probably effects mpg - negative cause it sounds so tough.
Cheers.
I have the Volant on mine.  I think it looks and is a better qaulity piece compared to the K&N.  Of course, I think it costs a little bit more.  Installation was simple.  It took me longer to remove all the factory pieces than it did to install the Volant.  I can't say I noticed a gain in power but it doesn't seem to need to "wind up" extra rpm's before shifting, but I did notice a slight gain in mileage.
Oh YES! This kit is worth the $...
Installed in about 1.25 hours last night. Noticed better acceleration or response right away. Now my flowmaster exhaust can inhale as strong as the exhale! Great sound too!
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 450 Guests (See full list)
