westin bull bar
I have a 3" body lift on my 2000 Z71, wanting to put a westin bull bar on it. Has anybody else done this and was there anything different with the installation. Thanks :cry:
  • 2 months later...
I have a 3" body lift on my 2000 Z71, wanting to put a westin bull bar on it. Has anybody else done this and was there anything different with the installation. Thanks :confused:
My best friend had the Westin bull bar with his body lift (3" from PA) looked REALLY good too. His truck was a 2003 Ext. Cab Silverado. 4x4
I have a 3" body lift on my 2000 Z71, wanting to put a westin bull bar on it. Has anybody else done this and was there anything different with the installation. Thanks :P
Thanks Doug!! :confused: Here are a few pics of the 03 so this will give you an idea wht it would look like - it has nothing to do with the lift because it's attached to the frame - it will only sit lower with a BL than when it did before the lift:
I have a '06 Sierra and it does attach where the tow hooks attach. You have to remove the tow hooks and then attach the bull bar. The bull bar does continue a little under the truck from where it attaches so that is what you may be seeing in the picture. It doesnt attach at the very bottom of the bull bar.
those pics look like he still has his tow hooks in...is this affected by the body lift? I've seen pics and the bar goes right into the holes where the tow hooks were...
His tow hooks were removed. THe Bull bar mounts in place of the Tow Hooks. When you do the Body lift the Bull bar will be relocated BELOW the bumper as seen in the above pics.
ok...that's what I thought (the tow hooks would no longer be in the stock location where the holes are)
