need a couple of torque specs
Hey everyone,
Can someone provide me a with a few torque specs?
I just installed a new driver side wheel bearing and half shaft..........I need to know the torque specs for the 6 bolts on the inner axel shaft, the spec for the large nut that holds the axel to the bearing and the 3 bolts that hold the bearing in.
I tightened everything up real tight by hand.........and once it was all back together, I could hear something binding as backed down the drive way......so I want to make sure everything is torqued down to spec.........I hope that gets rid of the horrible binding noise.
If anyone has experienced this and has some tips, that would also be much appreciated.
Thanks.......... :cheers:
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 542 Guests (See full list)
