Heater control problem
I've just bought a 99 extended cab silverado and on the heater/ac panel when its turned from panel to defrost does absolutely nothing...its stuck on panel and floor and winters starting up here in maine and i need to get this fixed...any ideas or input would be greatly appreciated.
Thanks,
Kyle
I've got a 2001 chevy, and in the past 2 months or so, the fan controls have gotten kinda screwy. Fan setting 1 & 2 no longer work, but I think it's just a matter of ordering a new control panel. They have them at the GM Parts Direct website listed as a sponsor, and I think they run about $90. So if the other options don't work, then it might be that.
Your symptomns describe a bad blower motor resistor assembly, not a control switch. Good news is I think the blower motor resistor assembly is cheaper and fairly easy to swap out.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
