PCM compatibility
sbw9056
Will a 2005 6.0 Silverado PCM work in a 2001 5.3 Silverado? I have heard the new computers are better and that you can do realtime logging and editing. Would it be worth it to swap?
Totally different animals. There's no way you could put an '05 PCM in an '01, or any other year for that matter unless the two called for the same part #. Even then, it would have to be programmed and that goes by VIN so would be programmed as an '01. If there was any chance on earth that this could be done because the part numbers are the same, nothing would be gained since it would be the same PCM with '01 calibrations.
I have no idea what you're talking about with real time logging and editing. There's nothing like that built into the PCM in any year. Oh, it may store a code and failure information, but they all do.
I'd forget about this one. It just isn't possible.
Thanks for the info and the speedy reply.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 1,046 Guests (See full list)
