Wet floorboard carpet 99 Silverado
luxrw
I have been experiencing a wet carpet in my 1999 silverado for the past few months. There is no smell of antifreeze and I have been in dry conditions and the carpet still becomes wet. I recently added a small amount of antifreeze, but not enough to compensate for the moisture in the carpet (driver side and passenger side). At one point, the driver side was so wet that when I would push down, water would come out. I have had no fogging or any filming on the windshield. When I use the heat, it seems to come out fine. I have even driven with nothing but the vent runnning and still the carpets get wet. I have kept in the garage thinking maybe rain was building up somewhere, but still wet. Any ideas?
There's no mistaking the feel of antifreeze if you get it on your hands. It's very slimy and simply wiping your hands with a dry towel will usually not remove it very effectively. So you should be able to tell if this is plain water or antifreeze.
If it's so deep that it soaks through the carpeting, I'd say you'd notice a significant loss of coolant in the reservoir.
No slime on the hands, so it must be some other source. It is affecting both sides ( the driver's side more heavily). I placed a white napkin underneath my mat to see if it would be red. After driving, I checked it. It was wet, but still white.
Okay, so it's plain water. Rain water or from washing the vehicle. The fact that it's on both sides *usually* elminates A/C condensate as the cause as that usually only affects the passenger side. Any aftermarket stuff whose wires have been run through the firewall and not properly sealed? See that all the time. But that usually affects one side too.
As mentioned to several others here with water leaks, you just have to water test with a hose and see if you can find the entry point of the leak. It's not easy.
  • 1 year later...
I am having a similar issue. I think the source of my problem is a grommel underneath the drivers' side floor. You might want to check that out. I noticed that water was coming in when it rained. Its gotten kinda bad but I don't know what to do about it. A temp. fix would be to put caulking around it but i dont want to mess with it after I fix it. If you pull up the floor trim, you can just pull the carpet and padding underneath and its easy to see if thats the problem. Mine is kind of moldy. I dont think you can buy just that seal, but if someone knows where i could get it that would be great.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
