cluster prob
fatbillybob
Hi,
Can you tell me where to start finding this problem?
2003 suburban 2500 4wd 8.1L
1)instrument cluster analog gauge all do not work. guage lights work fine. DIC works fine.
2) turn truck on and off several times no change
3) three days later start truck is cranks slow like dead battery but fires within 1 second and all guages work fine!
So could there be a short that is taking key-off power from the battery causing a drain in three days resulting in hard cranking? But why are my guages working now? Any ideas???
Thanks!
[email protected]
Subject: Instrument Panel Cluster (IPC) Gauges Inoperative (Reprogram IPC) #03-08-49-020 - (11/19/2003)
Models: 2003 Cadillac Escalade, Escalade ESV, Escalade EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003 GMC Sierra, Yukon, Yukon XL
Condition
Some customers may comment that upon vehicle start-up, all instrument panel cluster gauges are inoperative.
Cause
During a cold start or low battery condition, a low voltage condition may cause gauges to freeze during crank cycle.
Correction
Important: DO NOT REPLACE the following clusters unless a reprogram does not correct this condition.
• 15182138
• 15182139
• 15182140
• 15182141
• 15182142
• 15182143
• 15182144
• 15182145
• 15182146
• 15182147
• 15182148
• 15182149
• 15182150
• 15182151
• 15182152
• 15182153
• 15182154
• 15182155
• 15182156
• 15182157
• 15177467
• 15177468
A new service calibration has been released to correct this condition. Reprogram the IPC using the new service calibration, which was available from Techline starting November 3, 2003 on the TIS2000 version 11.5 or later. This calibration is an electronic calibration and is not available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N4199
Instrument Panel Cluster (IPC) Module - Reprogram
0.4 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
GM-Tech,
Thank You for your time.  You are most helpful.
last week I had my cluster stop working after a High Pressure under wash, The same conditions as above, The service tech told me that this must have caused a fault, Needless to say they re-programmed the cluster which cured the problem, $ 200.00 $ later.
Gauges on my 03 Yukon stopped working tonight for no apparent reason (warm start, battery is less than 6 mos old) so guess it's off to the dealer for this problem.
Thanks for the info GM-Tech!
Just remembered relative has a scanner so going to pull the code(s) tomorrow AM before take it to the dealer. Anybody know what code(s) represent the IPC inoperative condition?
So, checked the IPC fuse just in case and it looked fine. Got in the truck immediately after to go pull the codes and the IPC was working.
Put the scanner on it anyway and it registered no codes.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 838 Guests (See full list)
