4 wheel drive not working
guyno
i have a 1991 gmc k2500 got it with no right side cv axle. i just got one from a wrecking yard. got it put in and in 4 high going straight it felt like it was pulling side to side kind of like turning to tight on dry ground the guy i got it from said it had a bad front diff does this sound like that any help to get this tracked down :banghead:
Is it possible that it has an LSD or locker that is locking up, and that's why he removed the axle?
Its possible to that they got the wheel aligned w/o the axle on, and it might have thrown everything off.  Just a possibilty.
just got truck alingned and still have the same ting going on could it be the front diff
Check your tire diameter. You can do this by painting a strip on all 4 tires and rolling straight forward a few revolutions and seeing if they are close to the same spot. If they check out OK, post back.
    BigJake
    BigJake
  • Who's Online   1 Member, 0 Anonymous, 565 Guests (See full list)
