Replacement bumper
I plan on getting a full replacment bumper for my HD.  I need to know a little more on how they mount to the frame.  I've been looking at some and they seem to have 4 bolts holding them to the frame.  One on each side of the frame.  And one  on the top, of each side of the frame.  How strong is this setup?
I plan on getting a replacement that has the reciever hitch in it.  I want the reciever hitch so I can back trailers in tight places easier and so I can use a winch if I need and remove it when I don't need it.
Will this setup with the four bolts be strong enough to pull my HD out of the mud if I get stuck?  I don't mean like two inches of mud, I mean like burried to the frame(you never know when it might happen).  I sure don't want my bumper getting ripped off the frame.
Does anyone know of a good sturdy full replacement?
I believe DrawTite makes a front reciever that bolts on where the tow hooks bolt on but the tow hooks stay functional.  If I remember right it has a 10K lb capacity and you don't have to discard the stock bumper...
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,117 Guests (See full list)
