1991 suburban fuel pump (in tank)
doug123
I recently had a fuel pump wire lead connector melt and fuse to the exaust pipe.
I pried it off and it looks like only one lead (there are two wires) was exposed.This caused a short (wire on tail pipe) and susequent blown fuse on the ECM fuse slot on the fuse block.
I silicone sealed the connector. I replaced the fuse and was happy to see it not blow at my fingertips. I turned the key on and did not hear the fuel pumps lovely hum...........hmmm. I Turned over the engine and it oviously did not start up.
Should I test for current at the connector?, and if that is good should I then look for continuity at the same connector leading to the Fuel Pump.
Thanks in advance to all who reply.
Doug123
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
