Long Tube Headers
I'm looking into getting some Long Tube Headers for my '06 4x4. Question is, what did you guys with the LT Headers do with the other 2 (post cat) o2 sensors since most copanies don't make an LT, with or without a Y-pipe, with 4 o2 sensor holes. I know the first 2, pre-cat, will go into the first 2 mounting locations. Also, will all long tubes fit a 4x4? Thanks in advance
In my Camaro SS, I used O2 simulators. I'm sure they are made for any car with post cat O2s. I got mine from Year One.
Basically, they register a perfect mixture all the time.
-Pete
94Silverado
I know i need to use o2 simulators, but i would prefer to use the ones that i screw the o2 sensor into, then screw the simulator into the hole. I don't want to splice into my wires because i'll be having to switch the Long Tubes in and out when i have to get a smog check.
On the other hand, do you think shorty's are worth the $$? I don't believe i'm getting the full benefit of headers if i'm not getting Long Tubes.
Also, a supercharger is will be added in the distant future, so i know i'll be needing headers at some point in time.
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 630 Guests (See full list)
