weather effects remotes
Ok so I am using the factory keyless entry syaytem to activate my remote start, but I have noticed that when its cold out my remotes donty work for jack. It seems that if the temp drops below 50 or so my remotes hardly ever work. I have replaced both the batteries in both remotes and they both act up so im guessing the cause is in the truck, since the keys are in the 74 degree house. I have taken the remotes apart and cleaned the contacts. Anybody got any ideas, this really sucks having a remote start to warm up the truck, but yet it doesnt work. Is there an antenna for the keyless entry cause even when it works im lucky to be more than 50 feet away and have it work.
Could there be any other systems in your house or a surrounding building, etc. that might be operating only when it's cold out and that one of these systems might be operating on the same frequency as your remotes? Do you remotes work properly when you are in another place? I live in the Boston area and I have not noticed a change in the range of my remotes on my truck (an 05 model). However my Saab remotes are effective at ten feet or less (also a 2000 model). The Saab is in the driveway, very close to the house. The truck is down the street in a rented space. Just a thought....
Most of these systems are really only effective up to about 20-30 feet away. If you're getting 50 feet then you're doing quite well and I'd say your system is working flawlessly.
Edit: there have been times when mine doesn't want to work when I'm standing right next to the car...
Well i first noticed the problem when I went out snow skiing a couple years ago, it was in the high 30's and wse were saying in a remote cabin, since then I notice it all the time when the temp drops, doesnt seem any better in different areas.
Wheres the antenna for this maybe I can re route, extend whatever.
Hold the remote to the underside of your chin and try it. No, I am not crazy and have no scientific data to back this up, but it works.
Report back here on your results. :cool:
Holding it to your chin grounds it to you and since you are made of mostly water you turn into a big antenna.
I have tried that, and it has worked for me on previous vehicles, but not my truck, when it works normally this helps the range, but when it doesnt work normally this doesnt help, i can be standing at the drivers door and it wont work. i have tried the re-sync to that didnt seem to help either.
Report back here on your results.  :seeya:
It can't ground it to you. grounding requires electrical contact, plastic case is insulating the circuitboard from you. what happens is it turns your mouth into a "cannon" for the signal. doesn't greatly enhance range but it does effect it enough to gain a bit.
it works, i've even read it in a aftermarket remote start manual once.
but you do get some strange looks walking around the parking lot with your remote uder your chin and your mouth open.
I wonder if it is the chin thing, because it does work or the fact that you are now holding the transmitter (antenna) at a different angle.
ken
Under the chin is the only place that I have found that works. Admittedly I have not tried the underside of my sack, but only because that would just be silly. :D
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,259 Guests (See full list)
