IF you can't shoot it, run it over!
My 99 Yukon just did a 2000mi round trip to WI and back to VA. While home I had the luck of being able to go deer hunting. Of course I didn't get to shoot any, but my Yukon promptly decided to show me up by smaking one broadside about a day before comming home to VA.
This has done very little damage. The plastic grill is cracked and I should probalby go get a new one and the guard between the bumper and body on top is cracked a bit. I may think about replacing this if I find same color for cheap.
The main concern is that I have noticed an oil leak since comming home. Now, I have NOT had to accually add any oil, so I assume its a very slow leak, yet the pictures below lead me to believe it is an oil pan gasket.
What do you think?
I know this is easy to fix. Can I get the pan off without messing with the timing chain cover? Or does that have to come of first?
Thanks
-Robert-
Well I'd start from the premise that the pan was whacked out of position a mil or two when you ran over the deer.
I'd clean up the area...i.e some carb spray/parts cleaner, and a rag. Carefully loosen and re-tighten the pan while sliding it forward a mil. May be all it needs.
Did it leak before ? Did you run up-n- over it ?
If you did...keep in mind that it's 400-600 pounds of sloppy fur and hitting pretty good might be enough to push the pan back...especially if it's slightly loose.
Just a thought......
I live in wisconsin and I hate the deer.....they are very STUPID ! :cool:
400-600 lb deer?... WTF... its like deerzilla or something.
Yeah I went up and over it, but with the guard on it for the transfer case I doubt the deer made it up all the way to hit the pan. No, it didn't leak before. Just started leaking after....
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 542 Guests (See full list)
