Need Electronic Ignition Wiring diagram for Sonoma
Hi there,
I'm out here in the Amazon region (Belém-Brazil) and desperately need to have my Sonoma (93/4.3 liters) up and running. I recently bought it in order to restore it, and the distributor was missing. I rebuild the whole engine already, but since I can't lay my hands upon an original distributor I'm trying to use one from a local S10 (brazilian build). But I need a diagram telling me which wire (from the module) is what, in order for me to properly hook up without risking to blow up my module. Of course I could import a distributor, but because of the distance and local import taxes, that's quite a prohibitive alternative. The same applies to buying a manual (from the US) not only since airfreight costs are expensive, but mainly because I wouldn't be sure if the info required will be in there.
My request is thus: if someone who owns a manual which displays this particular piece of information (wiring diagram of the Electrionic Module) would like to pass me a copy, or maybe just tell me which wire does what (eg. red = positive, blue = tacho, etc...)...
I'd greatly appreciate
Jaime Baum
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
