Instrument cluster back lites
KKtrucking
Is it do-able in the shop to replace the backlight bulbs inside the 2003 Silverado instrument cluster? Or do I have to get a reman unit for 3 burned out bulbs? If it is do-able I don't suppose you gentlemen know of any LED kits to give it that ZO-6 look do you?
I had my 2002 Suburban cluster go out...they had to replace the whole thing because it's one sealed unit. Make sure you save the paperwork to prove that the speedometer was altered by a GM dealer when you go to sell the vehicle.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
