2007 Yukon Headlight Removal
PatrykKoul
  • 11 months later...
Anyone have directions on the removal of a 2007 yukon headlights? Do you have to remove the front bumer? Thanks-
no one???
It is not too bad but takes a lot of time. You have to remove the front section of the inner wheel well liner to get at the third of three screws that hold the light to the truck body. When looking at the exterior panel, this third screw is about two inches or so down on a 45 degree angle and towards the wheel well from the headlight's bottom outside corner.
To get to the other two screws, you'll have to remove all the top bolts holding on the front facia on to the body (they are just inside the hood and in front of the radiator). This allows the facia enough flex to wiggle the light assembly out of it's pocket. Lastly you'll be better off removing the front chrome grill so you can have more access to both sides. The grill is held in place with 4 screws and about 8 plastic friction clips that work similar to a wiring harness connector. These clips need the center catch to be pushed away from the facia so the grill will separate.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 461 Guests (See full list)
