Info Needed please
Hey can anyone point me in the direction of a audio wiring diagram for a 2000 GMC sierra 1500. I also have a newbie question. Do you need to check your transfer case oil and or change it? If you do haveto check it how is the best way to do so? I Think it is leaking after they put a rebuilt one in so any info is greatly appreciated. Thanks
Can't help with the wiring diagram. The T-case has a drain plug and a fill plug. Drain then fill until it overflows. I use a pump attached to a 1 gallon container to fill. IIRC, it takes a little over 2 qts...not totally sure on that though.
2000 GMC Sierra Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Window Trim
Front Speakers 6 1/2" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 4" x 6" Side Pillar
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
  • 3 months later...
Ground Black
Illumination Gray
Dimmer Brown
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Any idea if those would be the same for a 2000 chevy silverado??
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
