Best tire for 2500 HD
what is the best all around tire for the 2500HD Duramax nittto terra grappler seems good in a 18 inch wheel with torshion key lift and some lift in the rear 305/60//18 are the goodyear mt good I need a tire that does good offf road ad on highway.
I've got 285/75/16 BFG AT TA KO's on my stock HD rims. I do mostly highway driving, but I've had nothing but good experiences with the BFG's especially in the wear category. I went through two sets of them on my 03 1500 and that's why I went right back to them on my HD. I've heard that the MT's don't wear as well. For what I do AT's are the best tire for me. The Bridgestone Dueler AT Revo is also a great tire. I think with the BFG or Bridgestone AT's you can't go wrong either way. Good luck!
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
