Aftermarket Headunit install
Just picked up an alpine cda-9857 for my 2005 silverado 1500. I have the bose speaker system and also purchased the bypass for the factory amp. It says on the cruthcfeild website that it is required that I cut out the rear metal support bracket for the receiver to fit. Anyone done this befor, that can help me out? Thanks.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
