manual transmission noise
DCW
Here's the problem my transmission in my 1989 z71 makes a lot of noise in 1st, 2nd, 3rd & OD. 4th seem's to be fine & when your out of gear with the clutch it has like a loud ticking sound. A fried said it mite be my output shaft bearing. Any help would be great........ Thank's
The power flow through this tranny in 4th gear is strait through giving you a 1:1 ratio there for I would suspect that you have a concern w/ your counter shaft bearings or gears. I'm not sure if I understand the ticking noise condition. Is the clutch pedal released w/ the trans in neutral? which could be related to your input shaft bearing or through out bearing??????-WCT
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
