Trailering noob
I did a search but I have to say I couldn't find the answer to what I was looking for.
I am a complete trailering newb, I am adding a curt manufacturing class 3 hitch to my 2004 k1500 wt. I was wondering what kind of ball mount drop i would need to tow a normal trailer (I am moving and am planning on getting a uhaul trailer to cram all my stuff in. I know that my bumper is higher than the stock 2 wheel drive one. Do i need a 2 inch or a 4 inch ball mount?? Also since I don't have the factory trailering package do I need to purchase a t type connector to use the lights on the trailer? oh man so any things... so confusing thanks for the help!!!
For the electrical, you should get what is called a T-connector, Napa Auto Parts or any truck accessoriy store would carry them, and maybe U-Haul carries them, but , from my 20 years experience, don't let U-Haul do any electrical work on your truck.
As far as the Ball mount, I would get that from U-Haul. Thier prices aren't too bad, and that will save you trouble when you get your trailer.
good Luck...
uhaul does have the T adaptor. it takes you 2 min to do it your self. I like the one uhaul had because it had the flat 4 wire hook up and the adaptors for the uhaul trailers. as far as the drop shank. uhaul would be fine. the also make a few that you can adjust, so you can use it on more than one truck
So is this going to involve me splicing wires myself (which i can do pretty easily or will i just be able to plug it in with an already existing connector?
Just plugs in. (sometimes you have to run a ground wire to the frame somewhere)
  • 3 weeks later...
Thanks again for the advice. I got a good deal on a curt manufacturing class 3 . Unfortunately it took 4 hours to mount it because nothing would line up correctly!
You should be4 fine with a ball mount with a 3" drop or so. The idea is to have the trailer level with it loaded and attached to the tow vehicle. The trailer tongue weight should be about 10% of the total trailer weight and the load.
For a ball, I would go with a 2" ball. You should be able to find mounts and balls ar just about any parts store for around $25 for both. From what the local U-Haul store sells, that's about $15 cheaper!
The ball shank is typically 1" in diameter for up to 5000 lbs towing capaicty. The nut for the ball is HUGE!! You may have to take it somewhere to ge the nut tightened with an impact wrench.
yeah a pipe wrench works well - might need two. One for the top & one for the bottom.
either way you can always rent one at Home Depot or Lowes - buy it, tighten up in the parking lot then return. :shakehead:
Walmart sells a wrench specifically for tightening hitch balls for less than $10. I want to say it was $7.99 or so.
So do yall trust those adjustable balls that would be nice because i use the tri ball and my truck sits high in the hind end unless it is loaded heavy it rides slightly high at front of trailer, but that thing is solid as can be and makes me feel good, and all the ball sizes are readily available immediately info and experiences on the b&w turn around hitch etc. would be nice to hear
    FiLo
    FiLo
  • Who's Online   6 Members, 0 Anonymous, 642 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
