Wait4Me Performance Tune?
Is it really worth it?
Does it take alot of time to retrieve the PCM and uninstall/reinstall it?
What would the differences of a 5.3L 2005 be?
These have all been answered many times over I'm sure but thanks again.
ALSO! If you know of any better ideas as far as tunes go or better companies, let me know!
I think it was worth it. I picked up about 1 1/2 seconds on 0-60, and I get about 1mpg better if I keep my foot out of it. Install took about 15 minutes, half of which I spent looking for the pcm. Once you know exactly what your doing, no more than 5-10 minutes tops. Other companies to look at are westers and nelsons. From what I've read, it seems like maybe people get a little more performance out of them, but they cost 2 to 3 times as much.
I have a wait4me tune in my truck and I feel it definitely is worth it. And for $158 for a tuned PCM to replace your 'factory' pcm, it can't be beat.
I like mine. I got more power and about 2 mpg improvement. I am in Clarksville, not too far from you. I have a 5.3 4x4. If you want to take mine for a spin just let me know. I know some back roads that we could take out trucks and run them against each other to see if the tune made any difference.
Hey, neighbors! I'm down in Franklin, TN.
Larry
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 585 Guests (See full list)
