Help Removing Gm Aftermarket Stuff
cerbomark
Side steps are probably bolted to brackets underneith or to the frame. Tonneau cover is probably bolted or clamped inside the box somehow, lifting/rolling up the cover should tell you. As for the bedliner, they usually just slide in since they're usually just a fairly rigid plastic. I don't think any truck maker is offering a sprayed-in bedliner from the factory/dealer...That would be too permanent.
Just a question, why do you want to take it all off?
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,039 Guests (See full list)
