Leaf Springs On A Boat Trailer
xsports33
Do you need any special tools to take off the leaf springs on a boat trailer? Or is it basically unbolting them at the bushing and bolting the new ones back up? I don't want to replace them, i just want to get access to the bushings to lube them up real good. My trailer is squeeking beyond belief. I don't want to take them off to realize that i need some "special" tool to get them back on. Thanks all
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
