Lift Or Drop
So i want to make my silverado even, instead of the front downwards, should I drop the back or lift the front to make the truck look even? any ideas
Yeah I would definately lift the front! Even though when I did mine I did it even with 2 inches in the front and 2 inches in the back, but i do alot of towing so I switched the 2 inch block with a 3 inch!
Your truck looks like a 2wd, right? If so, you don't have torsion bars, and it's a LOT easier to just buy some drop shackles for the rear for about $40 and call it good. But if you want to lift it...The '01 in my sig is a 2WD with a 3" Fabtech suspension lift.
Yea its a 2WD, i think that sounds better... how much would it cost if i Lift the front 3" as well? and what kind of tires do you have on your 01 silverado.
The Fabtech lift kit comes with spindles for the front and blocks for the rear...Cost is From $700-$1000 depending on where you buy it (I just did a google search to get those prices), plus install (if you aren't doing it yourself).
The tires are 265/75/R16 BFG A/T's.
I lowered mine just the 2" in the back. I have pics at my cardomain if interested. It lends itself to a sportier look without without spending an arm and leg (about $40 - Belltech). It was easy to do and didn't take too long.
Thanks you guys.... i think i might lower the back just because its cheaper. ALL of Your opinions was really help full! thanks again
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 473 Guests (See full list)
