High Idle
rcaw
Hello,
I have a 99 Tahoe, 5.7L, no mods.
I have a problem with a high idle.
The idle will increase to about 1500-1800 RPM when
the truck is in Drive going about 30 MPH.
If I shift into Neutral the idle indicates 1500-1800 RPM
The idle will not come down until the truck
speedo indicates 2-3 MPH.
When in Park, I cannot duplicate the problem.
My question is why does the idle jump up at 30MPH when in Drive?
Why does it come back down at 2-3 MPH?
I have checked for vacuum leaks and have found none.
The Check engine light is on and code 0507 is indicated.
It just says idle control system RPM High.
I have cleaned the throttle body, MAF, IAC valve, changed the TPS sensor,
changed from CPI injection to MFI injection. Nothing has helped.
Any info or advice would be appreciated.
Where on the forum can I find the Idle Relearn Procedure?
Thanks, Ron
Never mind, I fixed it.
I replaced the lower intake manifold gaskets.
Passenger side gasket had failed, causing a vacuum leak
that I couldn't detect with conventional means.
Ron
So how did u end up finding it?I have the same symptoms and have cleaned everything under there and it is not consistant ,just does it once in awhile.
I read on another thread that if you have vacuum in your
oil dipstick tube that you probably have an internal vacuum leak.
I disconnected the PCV valve and plugged the PCV valve end of the
line that goes to the manifold. Then I plugged the PCV valve valve cover hole.
I also disconnected the fresh air tube on the passenger side valve
cover and plugged its hole in the valve cover. Plastic wine corks fit well
in the holes. I didn't need a vacuum gage to tell me I had vacuum
in the dipstick tube. It was a pretty bad leak. Previously I did spray carb cleaner
around the top of the upper and lower intake manifolds but there was no
change in the engine idle. So it was an internal leak.
This is the second time I changed the lower intake manifold gaskets.
This time I got the more expensive Fel-Pro gaskets. FPG MS98000T at NAPA.
I'm sure other auto part stores carry them also.
Ron
Ron
Thanks for sharing the whole experience!
How about any internal coolant leaks at the manifold? I hear the old OEM style gasket usually fails around the coolant ports. So actually it is quite a mystery to me why yours failed around the intake air area. Seems like bad luck.
Fortunately I didn't have any internal coolant leaks.
I only had a small external leak.
When I replaced the gaskets I smeared a very thin
layer of RTV around the coolant holes in the gasket.
I think the first replacement gasket failed because of
an amatuer installation job. (Me). I may have
improperly torqued the intake manifold bolts the first time.
On the second job, I was able to borrow a pretty sophisticated
Snap-On torque wrench that buzzes when you reach the
proper torque. I thought the click type was cool.
This wrench was really cool.
Hopefully the second gasket replacement will be the last.
I still have a slight stumble at idle. An independent tech
who also owns a Tahoe scanned my vehicle and said all
my switches and sensors are working properly. He said
I need 60-66 PSI at the fuel pump. Turns out I have 50 PSI.
He said that may be the cause of the stumble because of a possible
lean burn.
Last year I dropped the fuel tank to repair a fuel line leak and
a friend advised me to change the fuel pump. Good advice.
So I changed it. I had 85,000 miles on it. At 50 PSI, looks
like I'll be replacing the fuel pump again.
I'm always doing things twice, oh well live and learn.
It's a pain but I figure I am saving a ton of money doing it myself.
Ron
    KirbyCo
    KirbyCo
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
