Just Did One Side Of My Front Brakes
I would like to thank this forum for helping me save a s**tload of money doing my own front brakes. I'll admit, it was pretty tricky at first. My truck likes to rust...especially bolts. With WD40, PB Blaster, the right tools, my drivers side...which was squealing for about 2 months (i dont drive it alot now). I finally took on first.
It took some time...some trial and error attempts, but it worked! The Torx T55 Bit and a breaker bar worked wonders! I noticed, however, my outer pad was ok...could have gone another year. My inner pad was the one squealing. It was metal on metal, with the wear indicator worn away as well!
I used this indicator as a problem with the caliper pins, so I greased them up. I also greased up all the mounting hardware...so as to make for an easy removal next time.
Tomorrow i'll start on the passenger side, and i'll be done! The brakes feel kinda spongy..prolly could use a bleed, but i dont really know how to do that, so i'll take it in for that.
Always bleed the system before changing the pads or shoes on ABS equipped vehicles, this keeps the dirty fluid out of the ABS module and requiring replacement.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
