Water Leak In Nbs
This morning, I go to leave for work and as I back out of the driveway, water begins pouring into the rear seat from the holes where the rear seat seatbelts come through the corner panel interior trim. My headliner is soaked in both corners and the side curtain airbags may be wet as well. Leak seems to be coming in around the body seam where the cab corner meets the roof panel. Took the truck to the dealer today to show them. They are going to have to order a headliner (water stain rings in it already). They may have to replace the curtain bags also if they are wet. After the headliner arrives, they will schedule an appointment to fix the leak, install headliner, etc. Last night was a fairly heavy rain, no monsoon, though. Be sure to check your headliners for stains that may indicate leakage. I hope this is an isolated case!
Well that sucks. Must have been a defect when they put it all together to get that much water in there. At least it sounds like they're going to take care of everything, so that's good.
And hopefully it is an isolated case!
Do you have a sunroof? I have heard that there have been isolated cases where the sunroof drains are not installed properly and can leak.
Yeah, I do. I will hve them check the drains also. Thanks.
I have the NBS with a sunroof and noticed when I stuck my hand towards the front of the sunroof inside the truck while it was raining I got some drops on my fingertips. Is that normal and are there drains above the liner for this? Was not much but there was a little water from rains.
thanks
Bump... Anyone with a sunroof notice this and is it normal that there is some wetness and does it have a drain system?
Yes, they all have drains. No, you should not feel wetness if it's draining properly. Take it to your dealer.
Figured it would be you that responded Vmax and thanks. Well I only felt the wetness when it was raining and shoved my hand up towards the front of the sunroof corner and pulled them back with a couple drops on my fingers. You are saying that should not happen? Seems like the drain is above the headliner where I can feel metal so is that still a problem?
thanks
thanks
Not sure where you mean? Are talking about in the tracks where the roof runs? Or inside the truck?
thanks
Up above the liner there is metal I can feel when I wedge my hand up right beneath the sunroof. I felt some moisture up there. If you can envision the front edge of the sunroof directly beneath that like where the wind deflector is. Thanks for the help.
Well guess what guys. saw this post and just decided to glance in the corner of my truck and low and behold if mine is not leaking in both corners. Difference is, mine does not have a sunroof. Each corner has about a 2in. spot in the headliner. What next. The paint? cause it's already chipped all to pieces along the bottom and i only have about 4200 miles on it. But no matter what i still love the truck. after coming to this from a 04 tacoma it's like a cadillac. And the power diff. is great. :withstupid:
I am still waiting on a headliner, but I got to thinking about the sunroof drain theory... The drains all run forward to the windshield pillars. If they were not draining properly, I would have seen moisture around the sunroof opening before seeing it at the rear corners, as the rear roof height is higher than the sunroof itself. I did notice, however, that the third brakelight had moisture in it. I am going to have to have the dealer look at this also.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
