Reverse Light On At Wrong Time
teegee
I have a 1999.5 (2000) GMC Sierra. When I hit the brakes my reverse light comes on. I'm not sure where to start looking. Any thoughts would be appreciated.
  • 4 weeks later...
I tore out all of the trailer brake/light wiring and found the problem.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
