Timming Chain
Louigy
1993 GMC sonoma v-6 vortec If the timming chain has let go, What can i look for or should i do to confirm that this is the problem? Thanks..
Is the truck still running?
If yes then the timing chain hasn't broke
If no, what happened when it stopped working?
Need a little more details
