If I Just Pull The Tranny Pan
pastorscott
Im changing the tranny oil on my 04 burb. Oh yeah, do I have to remove any linkage to pull the pan ? Again
if I just pull the pan, how many qts of the new VI oil do I need ?
thanks
Scott
I believe the last time I changed fluid in my 05 5.3 Sierra it was 4.5 to 5 quarts.
May the force be with you,
Don
I think you are correct with 5 qts. Somehow I was thinking 7 but that is my wifes SUV.
Some people bend the linkage out of the way. I removed mine. You will need a torx bit that will fit on a 1/4 or 3/8 ratchet and you will find the torx screw head on the top meaning you have to come in from the top to get to them. Sorry, I cannot remember what size they are. Not a big deal.
Do you have a drain plug? If so, be sure you have a good quality 6 pt Impact style socket on a 1/2 drive pull handle before you start. Make sure it is fitting on the plug good and square and if it begins rounding the corners, stop. If it does this, you will need a propane torch to apply a small amt of heat to the plug to break the factory installed thread locker.
  • 4 months later...
what oil do you recommend to run? MY 04 silvy 5.3 has 55K and i wanted to go fulll syn all around.
I bend mine. It only needs to be a small amount. Iam not sure but you could probably leave it that way without problem. Mark. I use Mobil 1.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,259 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
