Cabin Heat Control
jchilling
I have a 2001 Tahoe with a standard climate control system.
Based on another thread in this forum, I replaced my blend damper actuator because when I turned my temp control to 100% hot, it would not go back to cool unless I parked the truck for about 30 minutes or more. After replacing the actuator, I removed all the fuses I could find relating to the HVAC system, the A/C, or the Heater. There were three under the hood and two in the dash panel. I left them out over night but the problem remains. With the new actuator in, I can now go up to about 75% of full hot and still return to 0% but if I go all the way to hot with the temp knob, I can't back it off until the truck has been shut down for an extended period.
Any suggestions are appreciated. Thanks in advance.
I tried pulling fuses on mine with the same problem but that didn't fix it. I reluctantly scheduled n appointment at the dealer for a recalibration. I think you'll need to do the same. I imagine when the actuator is replaced you have to set it to a certain temperature during the install, sort of like top-dead-center on an engine, so the new actuator knows the travel limits if not, you'll experience what you have now. The dealer recalibration probably sets those limits.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,046 Guests (See full list)
