Pillar Tweeters 07 Silverado
I replaced mine, along with all the speakers, and added an amp. I pulled the factory tweeters out, that was pretty easy. Had new ones installed at an audio shop. They clipped the plugs from the factory tweeters and put them on the replacements. Not sure if it made that much of difference though.
Thanks, I already had the door speakers replaced and an amp and and a 10 inch subwoofer in a custom box. Just didnt have the tweeters replaced.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
