2003 Tahoe Is There A Switched Fuse Anywhere?
I have searched the threads to no avail, I am trying to install an xm myfi in my 2003 Tahoe, but am unable to find a switched fuse to hook it to. I dont want to use the cigarette lighter because that is always on. Is there any fuse I can run the adapter to that will only work when the key is on?
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
