98 Yukon Starts Then Dies
dwagner3701
We have a 98 Yukon, it has been running good. the ditr, cap and wires have been replace as well as the bettery and alternator. I had a new fuel pump and filter 2 months ago. It just started this last night. It will start up every time - then die. you can't feather the gas to keep it running. Help Please.
i would love to give you some sort of an answer, but, could be a lot of things... it IS odd tho, the first thing i would think would be a fuel pump(dont think thats not the problem just because it was just replaced!!!! you could have a bad pump), so you need fuel presure readings(should be around 55 key on engine off)... also maybe a maf sensor(kinda doubt it, but maybe??) just unplug it, then the truck will go into limp mode for the sensor, if the mass air flow sensor is bad then the truck should run with it unpluged...
did it run good after you replaced the distributer cap and wires? or did you do that to try and fix it??? you could have screwed up the timing enough to cause it not to run or mixed up the firing order on the wires....
but you really need fuel pressure readings, and make sure that when you key on that the pressure holds without dropping much, if it drops from . .. ... say . . . 55 to 0 in like 1 minute then that is a big problem...
did you use ACDELCO parts when you replaced the pump? I have heard that aftermarket fuel pump on this one has some issues. Checking the pressure should tell you if the pump is the problem.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 472 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
