6.2 Diesel Hard Start
I have an 88 suburban with 6.2 diesel. When it sits overnight, it starts instantly, runs for 5 seconds and shuts off. Another 15 seconds of hard cranking and it starts again and runs perfectly all day long. Glow plugs are functioning correctly, outside temp 75 degrees, so not a 'cold start' problem.
I think the injections lines are getting air into them when it sits for hours overnight. Where and how I don't know. Since it starts quickly, the air must be close to cyl and when it stops, it doesn't stumble like no fuel in one or two cyl, it shuts off like I turn off the key. Started doing this last month....annoying. I checked the lines and don't see any fuel leaks. I have seen this problem with the older 6.2L mentioned on other forums but haven't seen a cause/solution.
Help, any ideas?
Phil
Help, any ideas?
Phil
I have just retired my 85 C10 burb,and put her heart in a 93 C10 PU,anyway,i think you have a mechanical fuel pump on your truck,it may have gone for s**t,there is no way you would not see a leak from the high pressure lines ,the fel pum pressurizes the injection pump,if it loose psi,then it stalls,hard to check though ,easy fix on right frt block,grease the pump push so it stays in place and position the lever correctly,hope my nonsence helps
  • 1 year later...
Help, any ideas?
Phil
Thanks for your imput.
Phil
  • 4 months later...
Help, any ideas?
Phil
  • 1 year later...
Help, any ideas?
Phil
Definatley sounds like your mech fuel pump to me, on all 6.2 diesels from '82-'93 the engines had a mechanical lift pump located at the bottom right front end of the motor, the pump diaphragm is most likley shot and will not deliver enough fuel to the inj pump, causing the injector pump to air logg, and the motor to surge. You should check your oil too, when a pump goes bad the rubber diaphragm usually tears and it will pump fuel right into the motor! -Brad
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
