Heater Blower Motor Stays Running
BigT's03
Hi,
I have a 2003 Silverado and this morning on my way to work the blower shut down and then started back up and went straight to high speed and is now stuck on high. I get to work and shut the vehicle down and the blower is still running????????? I had to disconnect the battery so it won't run all day. Any idea what would be causing this?
HELP
Thanks,
Tony
Hi,
HELP
Thanks,
Tony
well its been a few days since the post ,you need a new heater fan module ,located beside the fan,also check the connector,they have a tendency to melt ,connector kit is very expensive if required,this is very common,pull the fuse ,at underhood fuse block or disconnect the fan,
  • 3 years later...
I know this thread is pretty old, but i was wondering if someone could tell me where would be the best place to pick one of these up? Also should a fella replace the harness? Thanks
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 349 Guests (See full list)
