08 Nbs Sierra Exhaust Tip - ?
Looking for an exhaust tip for an 08 NBS Sierra. I measured the stock exhaust tip and its 2 3/4" I cant seem to find a inlet with that diameter. Anyone put on a stainless steel tip (clamp on) if so what size inlet did you use. Thanks.
http://www.gmpartsdirect.com/results.cfm?s...number=17801929
http://www.gmpartsdirect.com/results.cfm?s...number=17801927
http://www.gmpartsdirect.com/results.cfm?s...number=17801925
http://www.gmpartsdirect.com/accessories/frameset3.cfm
Thanks, I checked them out. Price is a little high though. I put on a 50 series Delta flow, and just looking for a single walled slash cut. Can anyone tell me what the difference betwen a dual wall and a single wall. I understand that there is an inner wall and and exterior wall, is that just to keep discoloration down from high heat exposer. Or dose a dual wall have another purpose?
The main purpose of double-walled construction is to lessen the chances of thermal discoloration. A tangential benefit is that you can mount the tip closer to the bumper, as double-walled tips will in general dissipate heat better than single-walled tips. Some manufactuers, such as Borla, also incorporate double-walled construction for aural purposes (these are their so-called "intercooled" tips). 2 3/4 is a fairly common inlet diameter size; while not as common as 2 1/2, you should still find a very large selection of tips.
Oh okay...I didnt know you had a different exhaust.
Did you just replace muffler or did they do a complete new catback with different exit?
I have a Flowmaster 50DF in my garage just waiting to be installed
I replaced my muffler on my silverado and might be looking to find a new tip too if i could find something that would look nice. Anyone have any ideas on some good looking tip set ups on the NBS??
Pete
I have a G35 Coupe that I replaced the exhaust on. I had my muffler shop weld the tip from the "G" on my Sierra. I think it looks great.
Lou
    CaptainDad
    CaptainDad
  • Who's Online   0 Members, 0 Anonymous, 503 Guests (See full list)
