Staring At My 2" Leveling Kit
I have had this CCM leveling kit for 3 weeks now. I have come close to installing it 3 times now and stopped myself. I have been waiting for my new Centerlines to show up so I can mount the new 275/60r20 tires I bought and get them on the truck first. Man I am torn, I am really thinking the stock stance might look cool with those new shiny wheels and slightly taller tires. Any thoughts?
Just wait and see. Not going to hurt is it?
Dude!!!
You ever see the "Dude" commercials? I am pointing at your sig pic right now and saying...
"Duuude"!!! :thumbs::D
Hey Daddy I have photoshop cs3, can you give me some directions on how to shrink the picture? ty
Go to Image>Image Size to resize. (Stay at or below 400 pixels wide)
Use Save for Web and then select a preset on the right that keeps your filesize small while also keeping good clarity on the picture. You should try to hit 25-40K max file size.
I'm also attaching a sig I did for you the other day if that makes it easier.
Dude!!!
"Duuude"!!! :thumbs::wtf:
Do you guys live next door to each other? Isn't that your ride parked right behind Jas's? :D
Daddy
I guess what is freaking me out is this "cut the studs with a hacksaw" on the instructions...so not being able to go back to stock is kind of a bummer. I need to do a bit more research. This does appear to be a high quality kit, however.
Dude!!!
Daddy
LOL I was just looking at that!!! Ahh yessss to have the short bus in my sig...I would be a proud man!
Understandable, however, at the very worst you'd need to buy new struts. Trust me though, you won't want to swap it back. :thumbs:
CUT ON YOUR TRUCK???? :thumbs:
Man you better think that out some more. Why not just send that kit back and get a ReadyLift or Procomp kit? No cutting anything.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
