Brakes Question Guys!
Need some help. Up here in ohio we got a $hit load of snow. I was making some deposits at the bank and i was on the verge of getting stuck. so i was spinning the tires to keep my momentum going when the brake light and the abs light came on in the dash. so my ? is do u think they might be wet or snow or something like that causing the light to go off or should i be heading to the dealer. I stop fine and everything my brakes still work. i have a 07 new body style chevy 2wheel drive with rear locker. anyways thanks for all info.
Ok, looks like a trip to the dealer is next. Sometimes when your spinning your wheels that will turn the ABS lights on , but they usually go right back off sometimes it takes turning the truck off and then back on to get them to go out. If the lights are still on there is something wrong.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,231 Guests (See full list)
