Lug Nut Pitch.
Does anyone know the thread pitch for lug nut on a 2001 Sierra/Silverado? I tried a search but I failed, miserably
Metric Wheel Nuts and Bolts Description
Metric wheel/nuts and bolts are identified in the following way:
The wheel/nut has the word Metric stamped on the face.
The letter M is stamped on the end of the wheel bolt.
The thread sizes of metric wheel/nuts and the bolts are indicated by the following example: M12 x 1.5.
M = Metric
12 = Diameter in millimeters
1.5 = Millimeters gap per thread
Yours may or may not be 12 x 1.5, so check to see what yours are stamped.
Hope this helps
Ask and ye shall receive! Norseman strikes again.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
