2007 Gmc Grille Fit A 2007 Chevy?
I don't really like the looks of the new Chevy grille's, and much prefer the look of the new GMC grille. Can I buy a billet GMC grille and replace my Chevy grille? Or are there key design elements that will make this difficult (ie. customization required)
Any help would be great, thanks!
Welcome. No, it is not possible. The hood, the fenders, the bumper cover, etc. are all different. If you replaced the entire front clip, you might be able to make it work but I doubt you want to make that effort.
You didn't notice this before you purchased? :lol:
Got a great deal on my LTZ from a dealer who used it at a few shows; only had 2,500 miles on it. Drove it from Texas to California, and that was that. I would have bought the GMC if I could have found the same deal...
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
