Trailer Wiring Question.
JLeosnow
Hello,
Is it safe to assume that the 12V power wire coming out of the back of the #4 position Bargman plug is regulated 12V power? The vehicles are a 2001 Suburban 1500 4x4 and a 2007 Suburban 2500 4x4. The power source for this wire on both vehicles comes from a 40A fuse block located in the under-hood fuse panel but was curious if they are indeed regulated. The reason I am asking is because I want to keep the the deep cycle marine battery charged in my trailer when towing but do not want to overcharge/cook it.
Thanks,
-John
No, it is battery power. On the older trucks, it will be 14.5V when running. on the newer trucks, it will be less as they have regulated voltage control. Short answer, what ever the alternator is putting out is what is on that line.
Thanks for the reply BlueGorilla. So, can I assume that it will maintain the battery in the trailer(when hooked up) just like it maintains the battery under the hood of the vehicle or will the trailer battery get overcharged? Sorry for all the questions, electrical is not one of my strong points.... ;)
Thanks,
-John
It will maintain a charge. It will not overcharge them as it will only get 14.5v Max. No problem. electrical is my strong point, well one of them.
Thanks for the reply/info BlueGorilla. Looks like I'm all set then! :lol:
-John
    DaleB
    DaleB
  • Who's Online   7 Members, 1 Anonymous, 1,541 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
